585,589 active members*
3,446 visitors online*
Results 1 to 9 of 9
    Aug 2005
    29
    how to control height with laser cutting.
    Hi all, We have waterjet cutting machine, and we want to add laser cutting.
    The problem is how to add height sensing and control. I have searched
    on line and seems the widely discussed capacitive or ARC control of
    plasmar may not apply here. I'd really appreciate if someone can
    shed some lights on what type of height sensing we should use.
    John
    Jan 2006
    2985
    I think height control is the least of your problems. Have you thought about beam delivery, exhaust, contamination of the optics from the waterjet, etc.?
    The big guys use a non-contact inductive or capacitive sensing method to determine the height above the workpiece.
    Matt
    Nov 2006
    22
    I have an Epilog 35w laser engraver... unlike a plasma or other cutting system, the laser is focused with a lens. This means that the focal point will not change from job to job... so as long as you have a flat surface, you set the distance once and run the job.
    In the system I have there are two ways to accomplish the focus... automatic and manual. In the automatic mode, the table starts to rise until a probe touches the surface... then the table lowers by a known amount leaving the lens the specified distance above the part.
    In manual mode, there is a magnetic gauge that attaches to the lens assembly, you raise the table until the gauge touches the surface than remove the gauge and start the job.
    Hope that helps,
    Jerry
    Jan 2006
    2985
    Jerry
    I suppose it would be useful to know what he is planning to cut, but I assumed it was thin metal. With thin metal the heat makes it warp and you have to move the lens to keep the focal point on the surface of the material. If nonmetallics are used, then you are quite right, no high control is needed.
    Matt
    Nov 2006
    22
    That could be problematic... but it would depend on the thickness and the amount of warp. The system I have wouldn't cut through aluminum foil... but will go through 1/4 plywood. The focal point (at least on my system) can be +/- about 1/16 inch.
    Aug 2005
    29
    Waterjet is good for cutting thick metal, but it is slow. So for sheet metal, we hope to use laser. My understanding from surfing the net, it seems in order to keep focused for a good cut, height control is very important to be with in 0.01". For people with experience in Laser cutting please comment on this, and most importantly, how to sense
    the height? What do commercial laser cutters use for sensing? I heard a rumer that some laser machines use
    gas pressure at the exit of the nozzle, is this true?
    Thanks in advance. John
    Jan 2006
    2985
    We run a 100W Kern and a 30W Vytek here. I have run Kern's metal cutting height follower and it uses a capacitive sensor, as I mentioned previously. A change in the distance from the copper nozzle to the workpiece produces a change in the capacitance. Measure this capacitance and you know your height. Now the controller will move the focusing assembly up or down to maintain said capacitance.
    Matt
    Aug 2005
    29
    Quote Originally Posted by ASTECH_CNCTools View Post
    For metal cutting, both plasma cutter and laser cutting machine can do, but plasma & laser are in different application and work demand.
    If for thick metal, waterjet, plasma are more suitable, but plasma without high cutting precision;
    If for sheet meal, laser cutting machine will be good choice.
    They’re both easy operation, but if want higher work performance, some operation knowledge & skills are necessary.
    And for laser cutter, don’t worry, the automatic focus system is also available.
    :boxing::boxing::boxing::boxing:
    Are you just here for advertisement??? The info you provided here are just basic knowledge!!!
    Aug 2011
    Hi, We use height control system on our industrial co2 lasers is this the application you are looking for?
  1. Disable Height Regulation on a Trumpf Laser?
    By CLT-Tech in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-21-2023, 04:21 PM
  2. Cutting speed locked to Z torch height control speed
    By Beefy in forum Mach Plasma / Laser
    Last Post: 02-15-2010, 12:14 AM
  3. Torch Height Control / Capacitive Height Control
    By ahlbebuck in forum Open Source Controller Boards
    Last Post: 11-27-2006, 08:32 PM
  4. Dynatorch Height During Cutting
    By edwardpic in forum DynaTorch
    Last Post: 10-31-2006, 12:00 AM
