584,850 active members*
4,247 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > arrow 500 y axis overtravel problem
    Sep 2007
    26
    Hello,
    My normally open (first) overtravel signal is not getting through, so it hits the hard stop switch and flags out. I have pulled the switch and it ohms out properly, so might be the cable. I am trying to track the cable through the back cabinet, but does anyone know if it goes to the axis control or to a different board where I can test it?
    Sep 2007
    26
    Update--- I found the cable on the input board and checked ohms -- no continuity where the table was parked, but got continuity after moving the table, so looks like the cable is the problem. I may try to align the machine a few times and see if I get lucky with it making contact just to get back to work for now, but will have to replace the cable soon.
    Anyone know what cable numbers I need to find replacement? I assume it has to be hi-flex?
  1. Arrow 1000 Y axis problem / Vickers AS10300 codes
    By Chaz in forum Cincinnati CNC
    Last Post: 02-24-2020, 08:31 PM
  2. Home/overtravel problem on Feeler Fanuc Oi-Mc
    By zarl in forum Uncategorised MetalWorking Machines
    Last Post: 03-10-2011, 10:33 AM
  3. Z Axis home position problem Arrow 500
    By BSavulis in forum Cincinnati CNC
    Last Post: 03-09-2011, 04:39 PM
  4. Overtravel Problem
    By mbpp in forum Fanuc
    Last Post: 04-13-2008, 04:30 AM
  5. Bridgport Interact 316 overtravel problem
    By mbpp in forum Bridgeport / Hardinge Mills
    Last Post: 04-02-2008, 02:13 PM
