585,992 active members*
5,238 visitors online*
IndustryArena Forum > WoodWorking Machines > CNC Machining Centers > Gerber Sabre serial card broken?
    Jun 2008
    17
    Anyone experienced problem w PC- to Gerber Sabre communication?
    My Gerber Sabre does not communicate with the PC. It is connected through the serial COM port. Tried with different PC:s. So the problem must be in the machine.
    Got the advice from a tech, to clean and reinstall the controller card and the connections that receives the signal from the PC, and to check the cable for damages.
    But to no avail. The tech thougt it most likely is the card that is the problem. But when he told me the price, and the fact that it's no refund if it isnt the card, I thougt Ill ask around if anyone have had the same problem.
    Thanks in advance for sharing experiences
    Ping
    May 2008
    85
    Any resolution to this problem yet?
    Jun 2008
    17
    Yes.
    Bought a new card to no avail. If anyone needs a communication card for 408 so give me a PM.
    I also had a new cable made (from the COM-port to the machine).
    Since I had got a new computer, i tried to switchback to the old one and voila, the machine worked.
    The new computer did not have any COM-port so I used a USB-COM converter cable. I guess that this may have been a part of the problem.
    I need to try the new computer with a COM card instead to see if that works.
    The best way you solve this problem is to ask the company which you buy this machine,I am a stuff in my manufacturer,and I know only ourselves know our machine best.
    http://www.morntech.com/: Laser engraving machine , CNC router
    May 2008
    85
    Sorry to hear that.
  1. Gerber Sabre 408 help...
    By crackstar in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-19-2018, 01:29 PM
  2. Gerber Sabre 408 Lead screw and nut
    By fbrinc in forum Commercial CNC Wood Routers
    Last Post: 12-28-2011, 12:00 PM
  3. Evaluating a Gerber Sabre
    By ToolslingerNJ in forum Want To Buy...Need help!
    Last Post: 05-22-2011, 02:51 AM
  4. Running g-code on gerber sabre 408
    By precise graphix in forum G-Code Programing
    Last Post: 08-04-2008, 07:37 PM
  5. Gerber Sabre 408
    By Pasty in forum Want To Buy...Need help!
    Last Post: 07-21-2008, 03:52 PM
