I am new to Okuma's and CNC in general so please understand if I state anything incorrectly. I have a Crown 1060 with a OSP-U10L controller on it. Everything moves in manual mode on the machine. I created a simple program that cuts a taper using a trial version of HSMCam Works and posted it using their okuma "generic" post processor. Everything works in the simulator through their software. I then use the MS-DOS function to load the program to the machine. So far so good. I can see the program name in the top center and the lines of code in the edit mode. When I try to use the dry run and machine lock functions to see if everything works, nothing. So I turn off the machine lock, nothing. Then the dry run, nothing. I thought that maybe with the chuck empty the machine was in a safe mode. Nothing still. I made the program even simpler and it still does not work. Below is the generic program that I tried last and it still didn't work. Would someone tell me if I'm doing something incorrect software related or does it seem machine related? There are no alarms on the machine, everything moves in manual mode. Also, the zero point is set at values of 3974.4387. I know that Okuma's are different with the decimal placement, but does that zero point sound correct? Any help is appreciated.
O132
N0002 M216
N0003 G00 X2 Z2
N0004 G50 S3500
N0101 M209 G00 X0.655 Z-0.085 TG=1 OG=1 G97 M3 S850 M42 M09 M63
N0102 M62
N0106 G01 X0.640 Z-0.060 G41 F0.0075
N0107 G76 Z0.0 L0.055
N0108 G01 X0.275
N0109 G40 I-0.0004
N0111 G00 Z0.16
N0114 G00 Z2 M9
N0115 M02
