585,698 active members*
3,316 visitors online*
    Aug 2011
    Milling machine, angle head, CAT-40
    Does anyone know of any angle head manufacturers besides "Madaula" ?
    We own a 4 axis, 3 year old Milltronics milling machine (Model RH-20, takes CAT-40 tools) and are looking to find some manufacturers of right angle heads. We have one manufactured by Madaula and it works great, but it is rather large. We basically need something that can get into the ID of a smaller part and do work, & also needs to have more "reach" in the Z direction to perform the desired work without crashing the machine's spindle casing into the work piece. Anyone?
    Aug 2009
    684
    Dec 2008
    3108
    Here's a couple
    SOWA
    Coolant Driven
    But did find a Co that did small heads
    - will put up on Monday from work
    Benz PDF - these may be a little higher priced $$$, not really sure
  1. 3D printer head in a milling machine?
    By vinot in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 03-01-2012, 07:47 AM
  2. Variable angle milling head
    By glsmaverick in forum Haas Mills
    Last Post: 09-02-2010, 05:36 PM
  3. adjustable angle milling head.
    By Beek in forum Cincinnati CNC
    Last Post: 04-27-2010, 05:52 AM
  4. right Angle Head help
    By inkydo69 in forum Mastercam
    Last Post: 04-08-2009, 03:58 PM
