585,753 active members*
3,717 visitors online*
    Jul 2004
    218
    E/G Sheet Metal Press?
    Is this even a possibility? If the press were very slow moving, could two halves be fabricated in order to stamp micro volumes of shapes into sheet metal? Could this material ever be cast strong enough to form aluminum sheets?
    Dec 2006
    325
    The type of process defeats the purpose of E/G this being vibration damping.
    best regards,
    Bruno
    Jul 2004
    218
    E/G has multiple advantages and uses. Though, the epoxy forms might be crushed under the aluminum's resistant toughness.
    Oct 2005
    2392
    If I understand you, you are asking about stamping cup shapes in aluminium sheet?
    You need male and female die pieces made of very hard polished slippery material and lots of lubricant, as most of the action is the metal sheet sliding over the die shapes under very high forces.
    If you are talking about making the die halves out of EG I think it is quite unsuitable, unless you have very thin sheet and gentle shapes (and low quantities before the dies are worn out).
  1. Recommend a Precision Sheet Metal Hyd Press Brake
    By CohaganEng in forum Bending, Forging, Extrusion...
    Last Post: 12-30-2011, 04:41 AM
  2. sheet metal unwrap
    By bostosh in forum Mastercam
    Last Post: 03-18-2011, 04:58 PM
  3. Sheet metal help!
    By revwarguy in forum MetalWork Discussion
    Last Post: 07-04-2010, 12:29 AM
  4. nx-sheet metal
    By sk96_me45 in forum UG NX
    Last Post: 04-30-2010, 05:58 AM
  5. Machining Sheet Metal
    By rchacich in forum MetalWork Discussion
    Last Post: 11-07-2009, 01:00 AM
