585,974 active members*
4,403 visitors online*
Results 1 to 9 of 9
    Apr 2005
    86
    Single surface probing
    I have a part (casting) I getting ready to machine and need to probe one surface in the y axis and translate that edge info. to the center line of the part.
    Using single surface #11 in the work offset page how do you pick up one surface and move it to another location and set you work offset to that postion?
    Part is 2.00 wide and need to set y0.0 at centerline. I need to translate from a Datum to centerline of the part?
    Or is there another approach I need to take?
    Thanks Don.
    Feb 2010
    1184
    Is it not possible to run the y-web cycle? Then it will automatically locate to the center.
    If not, you will have to insert a code like the following after it sets the single surface:
    Assuming G54, the macro register for G54 y axis is #5222
    #5222 = [#5222+1.0]
    Use +1.0 or -1.0 depending on which direction you are shifting.
    Hope this helps.
    Apr 2005
    713
    If you use the above example, you'll also need to move the Y zero back to where it was probed. Using his example:
    #5222=#5222-1.
    (probe)
    #5222=#5222+1.
    Or else it'll just keep moving 1" every time. I wouldn't do that. Depending on where you restart in a program, you could get screwed up in a hurry.
    Simpler: G52 Y1.
    Make sure to call G52 Y1. at each tool change. Then you can start at any tool change and have the correct location. If there's lots of tool changes:
    G52 Y[#500]
    Then simply changing #500 will move ALL G52 calls.
    Feb 2010
    1184
    Quote Originally Posted by Matt@RFR View Post
    #5222=#5222-1.
    (probe)
    #5222=#5222+1.
    Simpler: G52 Y1.
    G52 Y[#500]
    Good call! Didn't really think that one all the way through for potential problems.
    Apr 2005
    713
    I keep the broken probe stylus on my desk to remind me about this lesson.
    Apr 2005
    86
    Thank you both, I will give that a try.
    Thanks Don
    Apr 2005
    86
    So here is what I did.
    G52 Y-.9842 This set me at my centerline I was looking for. I also had to add G52 Y0 before my next WPC call out. Same tool working at G54 and G55 I had no need to shift G55. It works but is this the correct way to do this? Setting #33 to fanuc
    Thanks for the help.
    Apr 2005
    713
    Yeah, in that case I would do:
    G52 X0. Y-1. Z0.
    G54 M97 P100
    G52 X0. Y0. Z0.
    G55 M97 P150
    ETC.
    If you're only changing Y with G52, you don't have to type X0. or Z0., but I find that it's a nice insurance line for those times you have to start at any given tool on any given work offset. But again, not mandatory. Only M30, Reset, power off or a G92 call will reset your G52 registers.
    Apr 2005
    86
    Cool, Big thanks for the help.
  1. Fillet surface to surface problem
    By vincent13 in forum Mastercam
    Last Post: 02-10-2011, 01:15 PM
  2. probing
    By Freddy Bastard in forum Tormach Personal CNC Mill
    Last Post: 08-22-2009, 04:02 AM
  3. Surface to Surface Filleting and Trimming
    By cowpoke in forum Mastercam
    Last Post: 03-17-2009, 02:42 PM
  4. Replies: 12
    Last Post: 10-07-2008, 12:08 PM
