585,978 active members*
4,232 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Doosan mill/turn with Fanuc 31i ?
Results 1 to 6 of 6
    Aug 2006
    62
    Is there a G-code to change X values from diameter to radius?
    Feb 2006
    992
    Not as I know of, but it can easy fix if you have NcEdit/Cimco. And if you want sometime that free then you can do it with Wordpad or Microsoft Word.
    The best way to learn is trial error.
    Aug 2006
    62
    On mazaks I can use G122.1 to change from diameter mode to radius when milling. I would have thought the 31i control could do it.
    Jun 2008
    1511
    Quote Originally Posted by Integrexman View Post
    Parameter 1006.3 (DIAx).
    See attached.
    FYI I have seen this changed before and it can be very confusing and mistakes made by operators.
    Stevo
    Attached Files Attached Files
    Aug 2006
    62
    Thanks Stevo
    This parameter looks like it will change to radius for both turning and milling. I do not think the guys running the machine will go for this.
    Jun 2008
    1511
    My guess is that if they are already use to having this set to diameter then they will probably not like switching. As I already stated this can cause problems.
    Stevo
  1. Fanuc mill turn lathe post needed!
    By jake_tb in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 11-10-2013, 03:26 PM
  2. Doosan 2000Sy Ploygon turn????
    By mroy0404 in forum Daewoo/Doosan
    Last Post: 10-12-2010, 06:54 AM
  3. doosan fanuc 18t turret
    By julio_gyn in forum Fanuc
    Last Post: 05-19-2008, 06:43 PM
  4. Replies: 0
    Last Post: 04-22-2008, 07:20 PM
