Hi Guys,
Ultimax 3 control on a BMC 20.
I notice in tool setup that there is two types of coolant, Flood and Mist, that I can set for the tool. However the machine only has one type of coolant with two pipes. I'd like if possible to rig up a programable air blast. Some programs I want to run a cutter dry and then have coolant on for perhaps a drill and tap. This is just an idea but would it be possible to run a wire from something in the control to a solenoid plumbed into an air supply. I could rig up the air line easy and just have a manually operated tap on the outside of the machine but it would be nice to have something that was programed.
Just an idea.
