585,605 active members*
3,136 visitors online*
    Aug 2011
    Rotary axis - NcStudio - Aspire
    Hi, I'm just after a bit of advice, just got my first machine, a chinese 1325 type machine with a rotary axis, as expected from the posts I read on here, no manuals, I've drawn some bits in aspire and wraped the tool paths, but when I put the paths into NCstudio, and flick the switch to turn off the normal x axis, and the rotary on, it works but the distance of the rotations don't work out correct to what aspire thinks it should, so the part I routing rotates numerous times instead of once, do I need to change something in NCstudio for rotary maching?
    Nov 2007
    2466
    contact mark at vectric for post, [email protected] also there is a rotary section on the vectric forum, go to web site vectric.com > support > forum
    James McGrew CAMaster 508 ATC
    www.mcgrewwoodwork.com http://dropc.am/p/EJaKyl
    Jan 2012
    I have a machine very similar to yours and am having the same problems accept that we use Bobcad but did you ever fiqure anything out. Thanks
  1. A 5-axis CNC machine including a rotary axis
    By synthetiklone in forum CNC Wood Router Project Log
    Last Post: 07-12-2013, 09:32 AM
  2. Tipping rotary haas rotary axis
    By mfpuller in forum Mastercam
    Last Post: 04-04-2011, 04:16 PM
  3. NcStudio V5.5.60.0 HELP!!
    By Memoir in forum Community Club House
    Last Post: 09-30-2010, 07:16 AM
  4. Rotary head development 3 axis -> 5 axis
    By Mr Helmut in forum Mechanical Calculations/Engineering Design
    Last Post: 08-03-2010, 11:26 PM
  5. Rotary Tutorial for Aspire & V-Carve
    By rcnewcomb in forum Vectric
    Last Post: 05-17-2010, 12:06 AM
