585,712 active members*
4,335 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Haas VF-5 Renishaw OMP-40 probe
Results 1 to 10 of 10
    Jan 2010
    8
    Angry Haas VF-5 Renishaw OMP-40 probe
    I have a 40 taper VF-5 with a Renishaw OMP 40 spindle probe and have been having some issues with it lately. It functions as it should, except when doing a web, pocket, or bore probe cycle. While going through these cycles, during the rapid movements, all the lights on the probe flash at once and the controller beeps until the rapid movement is done.
    I can deal with lights and beeps. The thing that frustrates me is that after probing, when rapiding up to do tool change, the lights and beeps come back (yes, after the probe is shut off). To fix this, I simply run another probe cycle and return to Z home at 25% rapid and it seems to do all right. Starting to drive me nuts though so if anyone has any ideas of what could be wrong, I'm all ears.
    I've tried replacing the batteries and cleaning the lenses for the optical sensors to no avail.
    Thanks for looking!
    -Dave
    Apr 2005
    713
    That's bizarre. You're going to want to call Renishaw directly.
    Now I'm going to have nightmares about probes coming to life and hunting humans. Thanks a lot.
    Feb 2010
    1184
    Sounds like the probe is not getting the command to turn off or has turned back on. It lights up and beeps during rapid becuse the probe is that sensitive to movement.
    If you have the disk for your machine look to see if it has the Renishaw probe file. If so, you can try reloading the renishaw cycles. Maybe some of the programs got corrupted somehow.
    BTW, how old of a system do you have?
    Jan 2010
    8
    Home for the weekend now, but I think it's 2003 model. I got and reloaded the 9000 cycles within the last year or two (we had some other issues with probing). And yes, it is off and then about halfway back to Z home it turns on and beeps to beat all hell. The Haas dealer was baffled too.
    Quote Originally Posted by haastec View Post
    Oct 2010
    parts probe problem
    Rich
    What is your machine SN
    what is the RENISHAW macro version?
    If you don't know how to find this information, call
    the service department at Haas automation.
    It sounds like the parts probe is bad and not the macros
    Because it works good when the machine is rapiding at 25%.
    Do you have another machine with Renishaw probe, that you could swapp
    the probes.?
    TX
    Ismael
    Haas service Engineer.
    Feb 2010
    1184
    Is the probe a recently added/modified option or has this probe system been functioning properly until now?
    Has anybody worked on or repaired the probe recently?
    Get out your probe manual or download from Renishaw to double check the probe settings. When the batteries are connected the probe will go through a series of colored light sequences which represents the probe settings. Compare what sequence you see to the manual and see what that tells you.
    Good luck.
    Jan 2010
    8
    Thats what I was leaning towards but didn't want to hear...
    Machine SN is 40000, macro version I don't know where to look.
    Dave
    Quote Originally Posted by icamberos View Post
    Rich
    the probes.?
    TX
    Ismael
    Jan 2010
    8
    Came with the machine when new, and changed the batteries and went through the colored light sequence with Haas dealer on the phone. He told me it was correct.
    Good luck.
    Feb 2010
    1184
    At this point, I would call Renishaw and see what they have to say. I have always had good luck with their tecnical support.
    Keep us posted.
    Jan 2010
    8
    Will do, thanks for the help.
  1. Haas Renishaw Probe Programming
    By cnchouse in forum Haas Mills
    Last Post: 04-16-2014, 05:38 AM
  2. Haas Renishaw Probe Macros
    By DaOne in forum Haas Mills
    Last Post: 03-12-2011, 06:24 AM
  3. Haas Renishaw Probe
    By Tazzer in forum Haas Mills
    Last Post: 07-07-2009, 12:18 AM
  4. Haas Renishaw Probe, Files problem??
    By mgb1974 in forum Haas Mills
    Last Post: 10-24-2008, 07:15 PM
  5. Renishaw Probe on Haas VF-1
    By gromit68 in forum Haas Mills
    Last Post: 07-15-2007, 03:04 PM
