585,914 active members*
3,929 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > Rebuild Hurco Power Supply w/ PC Power Supply VMX30
Results 1 to 16 of 16
    Aug 2011
    12
    I have read that it is possible to rebuild a Hurco Power Supply using a PC power supply and an additional 24v power supply. I am not having any luck finding any schematics or instructions.
    Is this possible? We have a VMX30 purchased around 2006.
    I am confident that I can perform this build with the correct schematic and information.
    Any help is greatly appreciated. Once I get the information and perform the build I can post photos and procedures while I am working on the machine.
    Thank you, in advance, for any help.
    JD
    Jex Manufacturing Inc Elite Go Kart Racing Parts
    Feb 2010
    163
    I don't think it's possible to "rebuild" the power supply. I think you could replace the power supply with a PC power supply and an additional 24V supply.
    Find the color code of the wiring in the Hurco. I don't know if this changed from the old BMC's and KMB's that I know. The color codes for the older machines are Here.
    Hook up the PC power supply to +12, +5, -12. You'll need to trick the PC power supply to turn on. There should be notes on the web to do this. The notes should also cover the color codes of ATX power supplies.
    Get a 24V supply. Hook it up to +24 on the Hurco. Make sure it can handle the load. I'd get as big a 24V supply as I could find, at least 5 Amps, 10 is better.
    Connect the 0V/DC return of the power supplies together, and to the Hurco's 0V.
    Bear in mind that a PC power supply won't run with no load.
    Aug 2011
    12
    Thanks for the information. I suppose I meant replace and not rebuild. Just purchased a pc power supply from Best Buy and will get a 24v 10 amp power supply from Phoenix Contact. I will post my progress this weekend. Any other information is welcome.
    Thanks again,
    JD
    Mar 2007
    2083
    one of many links to use a atx psu as a bench power supply -
    Convert an ATX PSU to a Bench Power Supply
    for your use ,just link the green (power on) wire to one of the black (0v) wires to
    switch the psu on (black wires = 0v ,red = +5v ,yellow = +12v )
    you don't need to fit the 5 ohm 10w external power resistor to load the +5v output (across 0v and +5v ),
    as the machine control circuits should be enough, unless you need to test the psu on its own
    if you need to ensure the 24v supply can't be on without the 5v and 12v supplies
    you could use the +12v from the atx psu to switch a relay (12v dc coil) to control the mains to your 24v power supply
    alternatively use the power good signal (grey wire) via a 10k resistor to switch a transistor, to contol the +12v relay
    John
    Aug 2011
    12
    @ john_100 This link and diagram are excellent. Thank you.
    @ fasto Is there a way to confirm the 24v power requirements? I can get the power supply that I need, however, I want to make sure that I get one that is more than sufficiant without going overkill.
    This has been very helpful. I will be tearing into this project tomorrow hoping to be up and running by Monday. I will post progress.
    Thanks again,
    JD
    Jonathan M. DeLong
    www.JexMfg.com
    Feb 2010
    163
    JD the best way is to check the old power supply for a rating. If you can't find one you'd need to estimate the load by adding up all the 24V loads that could be on at the same time.
    My machine is a 1989 BMC-20 so it's probably a lot different from yours. As a guess any & all air solenoid valves & relays are 24V. All the lit pushbutton lights are 24V. The machine light is 24V but has its own transformer on my machine, yours may be different.
    You can estimate 0.1 amps for each relay, and 0.25 amps for each air solenoid valve. The lamps in the pushbuttons are probably 0.1 to 0.2 amps each. On my machine there's 17 relays and 6 air solenoids and 3 lamps in pushbuttons. That's around 5 amps or so. The microswitches & prox switches run on 24V and don't use much power. Some of the control might use 24V too. So I doubled my 5A to get 10A because I can't estimate any closer.
    Aug 2011
    12
    OK I now have 24v, 12v, 5v, and -12v.
    After power up I receive the following error...
    http://www.jexmfg.com/jeximages/winmax.shell.jpg
    Would this have to do with the power supply or is this a totally unrelated issue?
    There were 2 wires on the old power supply that are not hooked up...
    PG and -5v
    Does hurco use the signal from either of these? Would they be causing the error?
    Any help is appreciated.
    JD
    Jonathan M. DeLong
    www.JexMfg.com
    Mar 2007
    2083
    not sure what winmax.shell is, part of Hurco's software ?
    but I guess the fact it boots up and displays the error message
    it is almost working but has a damaged or missing file
    normaly a pc motherboard will not boot until it has the +5v power good signal
    in a pc the +5v is for the logic ic's , +12v motors in diskdrives and fans , and both +12v & -12v for the serial ports
    not sure what requires the -5v ,some psu's don't have it
    I assume it could be some types of memory and the -5v can also generated by one of the regulator circuits on the motherboard if required
    do you have another hard drive and disks to do a complete install
    with the 2nd hard drive you can allways get back to where you are
    John
    Aug 2011
    12
    Made some progress today. Seems the machine has a 2 part problem. Only related to a power failure that happened last week. Killed the power supply and also corrupted WinMax (Hurco software).
    I did get the power supply to work so far. I will be posting photos. I used a PC power supply from Best Buy. I also found out that our Hurco does not use the -5 vdc or the PG signal wire.
    I also used a Phoenix Contact 5 amp 24vdc power supply(info here http://rd.phoenixcon.com/products/in...3127_00_en.pdf ). I had this one in house rather than ordering a 10 amp and having to wait. Hopefully, the 5 amp will be enough.
    Now onto the software issue...
    Jonathan M. DeLong
    www.JexMfg.com
    Feb 2010
    163
    Yes you're making progress. I've never used a winmax system myself. There's a procedure that can be used to reload the software - if you have the disks.
    About the PG and -5V: most industrial pc's don't use the PG ("Power Good") signal as they've usually got a VCC sensor on board tied into a watchdog timer. The -5V is leftover from the really old days, and isn't used by anything on moden computers except perhaps the sound. It's still required to be on the ISA bus so it's still provided out of the power supply. It was used as the die bias on the 8080 CPU's. (Man, the 8085 was a huge improvement: single voltage, single clock, not that ridiculous 4-phase clock input the 8080 needed!)
    Aug 2011
    12
    I think we are back up and running. I learned a lot and have some good information that I will be sharing as soon as I get organized. Thank you for all the responses and great information. I will be posting photos soon.
    JD
    Jonathan M. DeLong
    www.JexMfg.com
    Aug 2011
    12
    Hurco VMX Power Supply Retrofit - a set on Flickr
    Here are some photos of the retrofit. I also added some captions explaining the process. I will add more information this week.
    Jonathan M. DeLong
    www.JexMfg.com
    Mar 2007
    2083
    just had a look at the photos
    I'm impressed,
    they show all the details required for the DIY power supply replacement
    clearly shows which wires to connect and the use of heat shrink insulation
    John
    Aug 2011
    12
    @John: Thank you for the kind words.
    A couple other points regarding this retrofit:
    1. If your current power supply is working take a moment and confirm the voltages and wire colors coming from the power supply. Write it down and keep inside your cabinet. This will save research time on what wires to connect for each voltage if you have to retrofit a new power supply in the future.
    2. Consider adding a battery back-up with surge, voltage regulation, and noise filtering to the 110vac going to the power supply. This will allow a few minutes to shut down the computer properly in the event of power loss (preventing file corruption). This will also clean up and regulate the power going to the power supply for added life. I will add another post with this installation. This is the unit that I used... SMART550USBTAA - UPS System
    3. It may be worth a call to Hurco support to get you back up and running. The gentlemen that I spoke with were fantastic and very helpful over the phone.
    Hurco CNC Machine Tools - Support - FAQ, Training, Application Notes
    4. Feel free to add your comments to this post or to the photos that I posted.
    Thanks again for everyones help, input, and feedback.
    JD
    Jonathan M. DeLong
    www.JexMfg.com
    Aug 2011
    12
    An update after appx. 2 years from my original post...
    Use a MeanWell power supply ( http://www.meanwell.com/search/qp-375/QP-375-spec.pdf ) for your +5vdc, +12vdc, and -12vdc. I found that the computer power supply cannot hold tight enough tolerance on the +5vdc. (Starts out just fine then after time starts to fade voltage.)
    Trim the +5vdc to 5.00-5.10 no more and no less. This is the most important voltage on these machines. Onlinecomponents.com | Authorized Distributor of Electronic Components usually has them in stock at a decent price.
    You will also still need the 24vdc power supply from Phoenix contact. onlinecomponents.com should have them as well.
    Phoenix Contact 5 amp 24vdc power supply(info here http://rd.phoenixcon.com/products/in...3127_00_en.pdf).
    Jonathan M. DeLong
    www.JexMfg.com
    Mar 2007
    2083
    Hi Johnathan
    may be the ATX psu you originally used may not of been the best example of the ATX supplies
    the updated supply looks good and should help othes keep their machines going
    I guess your mark 2 supply is like this :-
    Attachment 206244
    John
    PS
    looking at the data sheets
    the meanwell QP-375-5D is almost a replacement for the original supply
    the problem being the 4th output is only 24V @ 3A
  1. How'd you supply your power supply?
    By cnczane in forum DIY CNC Router Table Machines
    Last Post: 08-28-2011, 11:13 AM
  2. controller power supply 115/230v OK for Australian power?
    By Momill in forum Australia, New Zealand Club House
    Last Post: 07-07-2011, 05:06 PM
  3. More power from switching power supply
    By R.thayer in forum CNC Machine Related Electronics
    Last Post: 03-11-2007, 02:03 AM
  4. Power Supply from a computer power supply
    By jmytyk in forum CNC Machine Related Electronics
    Last Post: 01-11-2006, 09:56 PM
