I decided to build up a 4th axis for my table router. I have a new R8 spindle from an x2 machine laying around and I have always wanted to try the epoxy granite idea
Step 1: build mold box
I have plenty of solid surface counter top laying around. It has a pretty good finish and releases from epoxy decently with wax mold release.
Step 2: Prepare the spindle.
I am going to use 3 bearings, 2 are going to float in the epoxy and one in inside a aluminum shell for support. I did this because it was what I had available at the time. I would have preferred to press all of the bearings in an aluminum shell but at least this will show how good epoxy granite supports a bearing. I used foil tape to prevent the epoxy from getting into the bearings. The pictures show the fronts of the bearings open but I sealed them with foil tape also
