Dear members of the forum, I will appreciate your advise on the following issue.
I am trying to carve the face of a cylindrical body (half a cylinder)
The attached JPG is a 3D representation of the toolpath
As you can see, at the end of every pass:
1. The tool raises in a vertical motion to the height set as the clearance level
2. Descends again in a vertical path
3. Moves on to the next 3D pass
These vertical motions to the clearance level and back are an unwanted overhead.
I will be grateful if you could show me which configuration controls this behavior and how it can be altered.
Additional relevant information:
- The technology I am using is semi finish (linear)
- The geometry was set by selecting the target face
- I am using FANUC
Thank you
Ariel
