I think David can supply extremely good support. I agree Tormachs track record stands for itself and I could not tell anyone not to buy one of there machines if it fits the bill. THey are there, and will be and they stand behind there product, and it is a good one that does what is claimed.
But Davids track record is extremely good also even though all this is fairly new machines and company. His machine will totally outwork the Tormach in many ways. Its performance and abilities will stand out beyound a hobby based machine. If any kinda production is needed IMHO its no compairison. Again the Tormach is a great buy. But it is what it is, a good quality hobby machine that can handle some light production work ( all though with time, which a hobby or small one off production needs can take).
The tooling I dont think is totally its own thing. You can get a tooling setup pretty much just like this, if not exactly like it through Enco called Royal Products.
Enco - Guaranteed Lowest Prices on Machinery, Measuring Tools, Cutting Tools and Shop Supplies
His spindal may be made to except it dirrectly, or not, I am not sure but it appears to be the exact same taper setup ( may need a diff pull stud, may not). Interesting thing is it claims to give 100% holding which I was surprized of. It may be different, it should be looked into close to make sure, but I think its the same setup. Atleast the collets appear they would work.
Even if it is his own and tooling holders would have ot be bought from him only thats not bad, unless normal tooling is already in hand and will be wasted. Even then collets are something I find you cant have enough of, tapper types and bit holding size. More machines will be bought in time more than likely and R8 is so popular that a machine that uses them, or someone buying them will come along in time.
Davids setup are more geared toward production, even though afforable. He knows what he is doing and he is a great designer with more back ground and expeirance than most companies complete grew put together. I dont have anything to do with his company, but if I could afford it I would have one of his machines setting here. Of course I would not mind having a Tormach setting right beside it but I would not expect it to keep up with his machine.
As far as parts for the machines they each would have to come from the company that made them. EVen the tooling system for the Tormach, all though they can be bought at several places now.
There is not to many new company/machines I would have faith in if my needs where as yours. But Davids is one that I do and I wish I had one of his setups here right now. For now I can only hope to get the funds needed to finish my RF-45 conversion which is going into its third year because of several reasons. I would have loved to just had one of his setups so I could have hit the road running so to speak (with great results I might add).
Anyway using the time you do have to research and compair your needs to what you get is something you should take your time with. The more you know and understand the better off you will be when it comes time to make the choice. The tooling I bet David would look into seeing if the collets I linked to would work with his machine. Or exact specs may be had so you can tell yourself. Royal has very high quality products so if they work they are very good. A nice setup for any R8 machine out there if anyone is wanting a quick chnage setup. I will get a set if the funds ever work out, changing tools on my machine is a pain for me but I have dissabilities which makes it harder for me.
Good Luck, Jess
GOD Bless, and prayers for all.
