585,752 active members*
3,899 visitors online*
    Jun 2009
    108
    Cadet Mate OSP700M
    Good day!
    Someone could help me please?
    I have an alarm in a OKUMA machine Cadet Mate OSP 700M control:
    1-1 CPU-ALARM BUS ERROR (SYSTEM BUS)
    BUS ERROR STATUS (SBER,SBPAR,CYO,O,PRT,DIA,LOP.ECC)=80
    SSW= 0105 ACCESS ADDRESS=FC1000FC
    The led SREB is on at the MAIN1 BOARD
    I've tested the boards (Main1, Main2, Mem, SVP, etc) in other identical machine and worked.
    I've changed 3 fiber optic cables damaged, but the problem continues.
    I've changed the power supply but the problem it's the same.:drowning:
    Somebody have an idea what's happening?:drowning:
    Mar 2009
    1982
    1. changing main board is risky. Take care, let the machine boot nothing else
    2. alarm says it is bus error. So, check the bus
    3. No main 24V on this alarm, all optical interface devices are off.
    Nothing is on, by the way, on this alarm. It's just system monitor.
    Jun 2009
    108
    System bus error
    That's means that the monitor it's damaged, or some cable?
    Jan 2009
    74
    The access address tells the story on this type alarm. the FC1 part of the address indicates the problem is in the 2nd SVP board. try swapping it.
    Jun 2009
    108
    Thanks for your help, in fact I've find that the problem is the second SVP board part number E4809-045-158-B.
    I've find a replacement version C, do you know if are compatibles?
    That's means part number E4809-045-158-C
  1. Okuma Cadet mate RS232
    By Colinneil in forum Okuma
    Last Post: 04-08-2012, 09:24 AM
  2. OKUMA CADET MATE
    By Antonio Arguijo in forum Okuma
    Last Post: 10-09-2011, 02:26 PM
  3. Cadet Mate
    Last Post: 08-16-2010, 04:47 PM
  4. Okuma cadet mate 4020 -OSP700M 1999
    By Taehk in forum Okuma
    Last Post: 06-21-2009, 03:23 PM
  5. 1999 Okuma cadet mate
    By NCcustom in forum DNC Problems and Solutions
    Last Post: 03-23-2007, 12:43 AM
