I am new to machining, what is the rule on feed-rate and spindle RPM for metals (as well as plastics).
Is it just always better to go slow feed-rate (as long as time to machine a part is not a factor at all)?
As for RPM, is higher RPM better (other than when it generates too much heat to melt or weld the milled material to the tool)?
