585,763 active members*
4,045 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fagor Automation > Replacing 8025T CRT with 8.4 inch LCD monitor
    Nov 2009
    5
    I am going to replace the 8025T burned phosphor CRT with a 8.4 inch LCD monitor. I have to order two unit kits (minimum order from the Far East). They are approximately $450 each. Is any one on this forum interested in the second kit? I plan to mount the monitor on the left or the top of my 8025T console on my GT27 gang lathe. If anyone is interested in this second kit, PM me. I have some pictures and additional information.
    kenkad
    Jan 2012
    crt
    do you still have a spare crt for the 8025 series?
    May 2012
    17
    Re: Replacing 8025T CRT with 8.4 inch LCD monitor
    LCD retrofit monitors for any machine from 6.5" to 15" Color, monochrome, composite sync, separate sync. Universal Monitor
    www.monitoresperts.com
    714-995-0100
  1. Replacing a Haas Monitor
    By Depth_of_cut in forum Haas Mills
    Last Post: 12-16-2019, 04:21 AM
  2. Convert 8025T to PC Based Controller
    By Stinger.220 in forum Fagor Automation
    Last Post: 08-15-2012, 09:22 PM
  3. Reloading parameters 8025T
    By Captdave in forum Fagor Automation
    Last Post: 06-10-2010, 09:56 PM
  4. replacing maho monitor
    By pirke86 in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 01-05-2010, 05:08 PM
