585,665 active members*
3,119 visitors online*
Results 1 to 10 of 10
    Aug 2011
    Fagor 800t control (help needed)
    I have an ajax lathe fitted with the Fagor 800TGI control (only got it a few days ago)
    I have never used a cnc lathe befor only a Bridgeport interact with TNC150, so I'm sure i'm doing somthing wrong! I am trying get to grips with the basic features but when programming a basic "canned turning cycle" and then hitting the start cycle button the lathe moves to the "begin point" and then says "executing" but does not move anywhere? I have read this section in the manual repeatedly but still I have no idear why it will not actually do anymore than move to the "begin point"
    I should prehaps point out that the machine arrived with motors and drives removed and I have just fitted new motors and drives (correct replacment units) But as the axis all move properly via both jog and handwheels and it moves to the "start point" I'm at a complete loss
    Any help greatfully received
    Tristan
    Dec 2008
    154
    Check the Jog Control
    When this has happened to me on my 8025M, it has been because I mistakenly forgot to move the jog control off of the manual handwheel (or other non-manual override control position). Make sure it is selected to a manual override position 10-100%.
    Hopefully it is as simple as this for you also.
    R/
    Todd
    Sep 2011
    Same here
    I have a Chevalier 1840 with Fagor 800TGi and mine just started doing the same thing.
    At first it was dwelling for a few seconds when changing direction during a part program and then the feed stopped working all together.
    Handwheel works fine and rapid works as well....It rapids to the start of a program and then just sits there.
    No alarms either
    I hope someone out there has some advice.
    Jul 2013
    did anyone find a solution for this? im having the same problem with the threading cycle.
    May 2018
    6
    Quote Originally Posted by freightmaster View Post
    Tristan
    Hello please tell me if you resolve this problem
    I have similar problem
    May 2018
    6
    Quote Originally Posted by josseng View Post
    I wat to ask you if find a solution for this problem?
    Mar 2008
    169
    Re: Fagor 800t control (help needed)
    Check spindle Encoder
    Carlos Cabrera
    May 2018
    6
    Hello
    I change the spindle encoder but controller say execution threading ,but not movement.
    Thank you
    May 2018
    6
    Hello I see your post with problem fagor threading .Please tell me if
    you find a solution for this?
    Sep 2005
    6
    Check the following error screen. The servos might be out of balance. When sitting still the following error should be as close to zero as possible.
    Tom the Fagor guy
  1. Fagor 800t Error 064
    By jime in forum Uncategorised MetalWorking Machines
    Last Post: 09-17-2021, 08:40 PM
  2. Fagor 800T
    By blakey235 in forum Fagor Automation
    Last Post: 10-26-2019, 02:09 PM
  3. FAGOR 800T
    By blakey235 in forum EdgeCam
    Last Post: 05-09-2014, 12:14 PM
  4. Fagor 800T
    By Jones'r in forum G-Code Programing
    Last Post: 12-12-2012, 07:56 PM
  5. Fagor 800T
    By calaban in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-15-2007, 01:55 PM
