585,973 active members*
4,198 visitors online*
    Sep 2011
    Fagor 800t problem
    Hi - I'm new to CNC. We have just aquired an elderly AJAX lathe (Pinacho underneath) with Fagor 800t and AMC drives. The machine came without motors and we have just fitted brand new replacements.
    Having aquired control over the motors we have moved on to trying out some simple cycles, but everything we try results in the program starting, moving the X & Z to the safety position approaching the (non-existent for safety) work piece, then ..... nothing!
    Spindle keeps turning, no errors reported but program will not continue further. Screen shows "executing" but clearly it is not! Eventually we have to reset and try again. Getting nowhere. Can't see anything in the manual which would give us a clue.
    Anyone have a suggestion?
    Note: Unbeknown to me, It seems my business partner has also asked this in the Fagor Automation forum board - it is the same machine we are talking about!
    Apr 2011
    112
    Re: Fagor 800t problem
    Hello i have a ajax premier lathe that battery went dead. And i think i lost some parameters . Can you help me with some pics?
    https://www.youtube.com/watch?v=Ux5PWhELD0Q
    May 2018
    6
    Hello.I have a similar problem with lost parameter in
    Fagor 800T when battery discarge .If you fix problem please
    Send me parameters
    Mar 2008
    169
    Sorry parameter lost. You need a Fagor Tech
  1. Fagor 800T
    By blakey235 in forum Fagor Automation
    Last Post: 10-26-2019, 02:09 PM
  2. FAGOR 800T
    By blakey235 in forum EdgeCam
    Last Post: 05-09-2014, 12:14 PM
  3. Fagor 800T
    By Jones'r in forum G-Code Programing
    Last Post: 12-12-2012, 07:56 PM
  4. RS 232 connection fagor 800T
    By fixitonce in forum Fagor Automation
    Last Post: 12-01-2012, 04:51 PM
  5. Fagor 800T
    By calaban in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-15-2007, 01:55 PM
