584,849 active members*
4,494 visitors online*
IndustryArena Forum > Community Club House > Set variable values in Fanuc
    Sep 2011
    Question Set variable values in Fanuc
    Hi.
    I am programming by hand in an Fanuc 18i and I really need to make some variable values to increase an value for each time the program runs.
    And the value needs to be set in instead of an Z or X value.
    Also need to make an limit for the value so if the value gets to big the program jumps out. Equal or bigger than limits.
    Used IF and OR finctions on an Okuma OSP controller some years ago but I haven't found out yet how to make variable values on a Fanuc.
    I think it is something like this, but I am not sure :
    #1000 (variable)
    and you set this to an ammount, like #1000 = 10
    Am I on the ringht or wrong track here??
    Thanks for all help.
    aknap, norway
    Aug 2009
    684
    You need to find out if your control has Macro B capability to use that kind of programming notation. Custom macro variables on your control could range from #100-#199 and may have #500-#599 (even up to #999). Don't use any higher numbers unless you want to overwrite a system variable...
    DP
  1. Displaying variable values onscreen?
    By facegarden in forum Haas Mills
    Last Post: 04-30-2023, 10:23 AM
  2. Common Variable values output into a program
    By yaji63 in forum G-Code Programing
    Last Post: 05-17-2012, 06:17 AM
  3. Replies: 20
    Last Post: 11-14-2011, 02:41 PM
  4. Fanuc m15 how do I reset limit(s) values?
    By stoney459 in forum Fanuc
    Last Post: 01-08-2011, 01:15 PM
  5. Replies: 0
    Last Post: 12-27-2010, 09:55 AM
