585,698 active members*
3,487 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Prolight 3000 turning center C-axis driver failure
Results 1 to 1 of 1
    Sep 2011
    I've encountered a problem with my Prolight 3000 turning center. I was learning how to use the machine by cutting a few tapered spacers when the machine buried the bit resulting in a stall. I cleared the machine and then the tool turret started acting erratically. It's very jerky as it rotates and it won't home correctly. I've been told by the factory that the driver is burned out and that they need to replace it. Is this something that I can fix by replacing a chip or is it much more complicated?
    Thanks.
  1. proLIGHT 1000 Machining Center problem
    By Sethman in forum Commercial CNC Wood Routers
    Last Post: 12-27-2011, 10:57 AM
  2. Prolight 3000 tool turret problem
    By Robert440 in forum Benchtop Machines
    Last Post: 09-10-2011, 03:00 PM
  3. Replies: 0
    Last Post: 12-24-2010, 12:09 PM
  4. Emcotronic driver board failure
    By Adee in forum Stepper Motors / Drives
    Last Post: 05-13-2008, 05:42 PM
  5. Turning Center G40 G41 and G42
    By jorgehrr in forum G-Code Programing
    Last Post: 04-14-2007, 04:48 AM
