585,981 active members*
4,470 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Prolight 3000 turning center C-axis driver failure
Results 1 to 2 of 2
Threaded View
    Sep 2011
    I've encountered a problem with my Prolight 3000 turning center. I was learning how to use the machine by cutting a few tapered spacers when the machine buried the bit resulting in a stall. I cleared the machine and then the tool turret started acting erratically. It's very jerky as it rotates and it won't home correctly. I've been told by the factory that the driver is burned out and that they need to replace it. Is this something that I can fix by replacing a chip or is it much more complicated?
    Thanks.
  1. Prolight turning center mach 3 conversion
    By diyengineer in forum Benchtop Machines
    Last Post: 11-05-2019, 05:55 PM
  2. WTB: ProLight 3000 Turning Center
    By dmalicky in forum Benchtop Machines
    Last Post: 05-06-2014, 04:23 AM
  3. Prolight 3000 turning center (lathe)
    By closetgenious in forum Maintenance DIY Discussion
    Last Post: 02-07-2014, 06:05 PM
  4. Prolight Turning Center convert to mach 3?
    Last Post: 09-05-2013, 12:58 PM
  5. Prolight 3000 turning center C-axis driver failure
    By Robert440 in forum CNC Machine Related Electronics
    Last Post: 09-10-2011, 03:05 AM
