Flipping the work piece that is...
Long story short... I'm planning on making some MDF cabinets with drawers in them when I get my new machine in about 4 weeks. I've been scribbling plans on bits of paper and I think I'm over-thinking the drawers.
The long(er) version:
Assuming I've got a slot all the way around the bottom of the front/back/sides to hold the bottom of the drawer in I believe I should have the 'inside-up' on those components to do the machining.
I'm going to have a 'front' panel attached to the front of the 'box' which will be wider than the box, so I was also assuming the front panel would be machined 'outside-up' to put a some detail on the drawer fronts. The front panel will be attached via the long drawer pull machine screws and some wood screws.
That leaves me with a dado joint at the back of the drawer, and a ???? at the front.
If I use a rabbit with the slot in the sides I have to flip the 'inner' front panel to make the rabbit and if I use a dado I need a slot for the sides to sit into the inside of the outer front panel so I'd have to flip that and not have the detail I wanted on the front.
You see what I mean... Over thinking it. :-)
So, do I just rabbit the front edge of the sides and have the inner front glued and brad nailed / stapled on? Is that strong enough for a drawer?
I'll be using light weight drawer slides, the type that go under the drawer and have two nylon rollers one on the rear of the drawer and one on the front of the fixed slide. (If that makes a difference)
Or, alternately.... Is there some cunning design trick that I should use that I don't know about and couldn't find using google.
Cheers, Confused.
