Originally Posted by
Roberto Hodgson
Hello I am Bob as everyone when introduce himself, I am new in cnc machine and is my first post on CNC Zone.
I am a medical doctor whose hobby is RC airplane.
Ok let's go to the point. Last month I receive an apparently new machine, from a Hong Kong site ignoring the advice what some people said on some forum about the site.
My machine is a Walter 6545L. It came with no parallel cable, with no energy cable for 110V that I asked for because my country has 110V, the cable for the X, Y, Z where wrong configured, the plug for the spindle won't matched with the control box. So I had to change and fix all those problems. When I try to start the machine and Estop button, won't work at all on the axes and spindle. A Chinese electronic worker said me that there was a LED on, saying that there where short circuit on the VFD Spindle, circuit board, no Volt on the spinner, output socket and on the steeper motor output where about 14V, and this won't moved the axes. Then I reviewed the energy, input socked and the fuse and I realized that they sent me a 220V control box, it was another fix I had to do and active my 220V switch of my home and so, the short circuit LED on, goes off and in a short time I register with my multimeter in company of an electronic worker a voltage of about 24V on the three axes output and the spinner output, that made the axes work for a short time (happy for short time) No smoke, no bad odors, no burned PCB, but I suspect about some microcontroller on the interface card (Breakout board) with the parallel port and output, pins data to the 4 axis drive and spindle drive . After all, this nightmare, the control box was dead, no matter what multiple, configuration introduced in Mach3 software. (after testing my PC parallel port which is Ok, if I disconnect the data cable to those board the knob for each axis turn hard to move)
I sent many pictures to the sender on Hong Kong and I think. they recognized, that there are, multiple problems, because they told me that they will be sending another control box and a VFD apart not integrated. But, because I am not sure about that, I sent them an e mail via PayPal to confirm, before the end of the complaint time and they answer me saying that they can recognize me 400 USD (the machine cost was 1,440.00USD) I told them, that, I only want the machine functioning and I will be, OK.
Excuse me for all this history because I only want to know, if anybody can help me finding a solution.
I think that the problem is in the interface card. If I disconect the data cables to the axis drives all the axix motor are charged, plug again and no energy to the motors (easy to move, the Knob) If another interface card or control box that match my CNC machine stepper motor spindle and water pump can fix those problems I will be grateful with you, thanks beforehand.
