i have a oi with manual i guide on it when using the conversational to mill a od. chamfer, arc on, arc off it is stepping into part. have changed everything i can think of . can any one give any help
What axes are you working with?
Have you not simply copied the contour figure you used to mill the od?
Have you specified a convex (not concave) figure?
What angle are you arcing to?
Have you tried a 'vertical' approach/escape?
What difference does altering the cutter offset/chamfer size make?
Has the figure got enough 'depth/height' from base position to accommodate the cut depth?
Well there's some wild stabs in the dark....
DP
i am running a horizontal boring mill using x and y .i have tried diffrent angles with no changes also this program starts at -90 and most other either start at 0 or give you a option where to start this dosen't is that normal .i have had no formal training on it so i am kinda struggling on some things thanks for the reply
