Hey folks a little machininng question. I have a cavity with straight sidewalls thats perpendicular to the bottom. Its leaving alot of tooling marks or guages in the straight side walls. Is there a way to clean this up. Im using mastercam and it has a option to leave stock on drive and also a option to leave stock on check. Should you leave any stock on straight sidewalls as mention above. It only happens when I have cavities with these straight side walls, if the cavities have arcs or curved bottoms its no problem. Im thinking the issue is more cam related than milling issues. The model has no surface imperfections so Im for sure its not the 3d model. Thanks Rick
