If you want to skip my story and help me on my question... skip down to the red line...
Well guys.... I have a hell of a problem.... Bought my first Bridgeport yesterday... Found me a series 1 with Dro, vise, 12" rotary table and all for good deal and went to get her yesterday... Been planing to get it for over a week and made it a done deal before driving 6.5hrs round trip to pick it up....
Seller loaded my buddy's 3/4ton Cummings with a very big fork truck, truck only sagged 3" and it handled it perfectly on the way home... (2) 2" ratchet straps held it just fine and never moved an inch... completely uneventful!...
I had a friend from work come over with his truck, trailer & Bobcat w/forks to take it off the Dodge.... This is where the story changes!.... This dummy comes over drunk as hell, from tailgating the Michigan game all day... at this point... (you know where this is going right?)... He comes off the back of the trailer like a bat out of hell, up to the side of the Dodge, everything okay at this point.... slips the forks under the ram... I ratchet strap his forks together to keep them from spreading out... He lifts 3" and Dodge get the hell out of Dodge!... Lowers and continues on... He makes it all the up the gravel driveway, to the garage. Now, I was walking beside, using all my weight steady it as much as I could... when he gets to the garage, he just hits a lever just right and my new pretty BP starts taking a very slow fall, column upright & off the ground by1"... I gave it everything I had to keep it from tipping (i'm no little guy!)... unable to keep it from going... I probable slowed the fall some but at about 40deg...I had to let her go, or loose limb... falling of course on the concrete completely unforgiving of the load that of which has been thrown upon her...
At this point, I had a hard time deciding if i need to scrap out my drawers right now or if I should wait till this was all done... I strapped around the ram/turret and righted her... forks now at the bottom just pushing & scooting her 10ft or so into place (instead of letting him try again!)... Got it in place and stripping the shrink wrap from it, checking for damage which was inevitable.... My Dro box took some damage and it hit the ground and got slightly distorted... easy fix, and still works!.... However the (standing in front looking at the BP) right side of the table took the fall landing on the end of the table and the handle hit the ground first, then rolling somewhat to the Dro box where it stopped... The handle is bent, but somewhat usable or until I find another... but the table will not screw back and forth, fearing the worst, thinking that the long screw had sheared.... I found that the head of this bolt (circled in photo) sheared off and shot the 2 brass nuts/sleeves out that side preventing any real damage it seems!... Checking it all out... no other damage was really done & I'm really lucky, considering... The knee was rolled all the way down and the head flipped completely over, keeping the weight low...
I rolled the brass nuts all the way left and slid the table right to left by hand and everything still feels nice & tight. I was able to line up the slot on the brass nuts & get one of them to slide back into the bore... now able to screw the table back and forth... It seems like its fine.... However, I can not get to that bolt in order to extract it... There is enough bolt sticking out I can maybe remove with pliers or at least that I should be able to get it out easily if i can just get to it... I need to remove the table to do so... Can anyone give me some advice on doing so??? I check everywhere online and can not find anything on removing the table... even youtube!
Any help with some instructions, a video or maybe a download of a repair manual would be great... I found the downloads from Hardinge- Installation, Operation, Maintenance and Parts List... but it only shows how to tighten that bolt to set backlash...
Thank you guys for anything and everything you can help me with!
