585,973 active members*
3,943 visitors online*
IndustryArena Forum > CAM Software > UG NX > NX7.5 Post Builder
    Sep 2011
    NX7.5 Post Builder
    I'm using NX7.5 to program a Okuma VTM200YB. On the Okuma, when using cutter comp, it needs a tool offset consisting of three offsets eg: The code would be TL=101010 if I was using tool 10, offset 10 and cuter comp offset 10. If I was using tool 12 it'd be TL=121212 etc. The problem I'm having is when I post process it only comes out with two offsets. I've tried altering it in post builder but I've had no luck thus far.
    Any help would be appreciated.
    Mar 2011
    srl,
    I have done something similar using a custom command placed in the operation start sequence. This custom command will automatically set your length and diameter offsets if you have left them at 0 while inside NX. Let me know if you need a hand or if I've made a mistake.
    the code I used was:
    global mom_tool_number
    global mom_cutcom_adjust_register
    global mom_tool_adjust_register
    global mom_cutcom_status
    global nr_tool_adjust_register
    global nr_cutcom_adjust_register
    global nr_tool_number
    set nr_tool_adjust_register $mom_tool_number
    if { $mom_tool_adjust_register != 0 } {
    set nr_tool_adjust_register $mom_tool_adjust_register
    # sets your H number automatically
    if { $mom_cutcom_status == "UNDEFINED" } { return }
    if { $mom_cutcom_status == "OFF" } { return }
    set nr_cutcom_adjust_register $mom_tool_number
    if { [info exists mom_cutcom_adjust_register ] } {
    if { $mom_cutcom_adjust_register != 0 } {
    set nr_cutcom_adjust_register $mom_cutcom_adjust_register
    # sets your D number automatically
    set nr_tool_number [ expr (10000 * $mom_tool_number ) + ( 100 * nr_tool_adjust_register ) + ( nr_cutcom_adjust_register ) ]
    #RENAME YOUR TOOL BLOCK AS $nr_tool_number
    #PLACE COMMAND IN OPERATION START SEQUENCE
    Oct 2012
    12
    nx
    you have skype id................my id add _nximran
  1. CNC builder
    By curious1 in forum Mentors & Apprentice Locator
    Last Post: 04-05-2007, 06:46 AM
  2. New Builder - CNC Router
    By DannyR in forum DIY CNC Router Table Machines
    Last Post: 04-28-2006, 04:41 AM
  3. New CNC Builder
    By kheri in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-31-2005, 05:08 PM
  4. another first time cnc builder
    By dansal in forum CNC Wood Router Project Log
    Last Post: 06-23-2004, 09:52 PM
