585,557 active members*
3,374 visitors online*
    Jan 2011
    Haas aux 3/4hp coolant pump
    Does or has anybody found a cheaper cost replacement coolant pump for a HAAS VF1 , The 3/4HP HAAS pt # HA-93-30-0128. My pump is on its last leg and $500.00 is a little pricey for me.
    Jul 2005
    12177
    Is the pump or the motor on its last legs? I have found that the starting contacts on the motors fail long before anything and these can easily be replaced.
    Jan 2011
    the pump housing is cracked and so is the motor cap around the bearing.. The unit is shot its just a matter of time before she implodes.
    Gusher Pump
    Give Gusher Pump a call. I think they make them for HAAS. Ask for someone in technical support.
    John
    2007 HAAS TM-1P OneCNC XR5 Mill Pro. Shopbot PRT running Mach3 2010 Screen Set, Super PID and PMDX Electronics.Check out my Gallery on: http://[email protected]
  1. Tm Coolant Pump
    By behindpropeller in forum Haas Mills
    Last Post: 03-15-2010, 04:45 PM
  2. Coolant Pump
    By bobs_charger in forum Tormach Personal CNC Mill
    Last Post: 04-16-2009, 11:19 PM
  3. Coolant Pump
    By Smackre in forum Mechanical Calculations/Engineering Design
    Last Post: 06-29-2007, 07:16 PM
  4. coolant pump ???
    By Loadedagain in forum Charter Oak Automation Support Forum
    Last Post: 01-03-2007, 07:54 AM
  5. Haas VF2 Coolant Pump (Pressure) Question ...
    By Mike Braddock in forum Haas Mills
    Last Post: 06-09-2006, 01:54 PM
