585,996 active members*
4,083 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Need dimensions for housing bolts (not mounting bolts)
    Aug 2007
    422
    Question Need dimensions for housing bolts (not mounting bolts)
    Hello,
    I need locating dimensions for the screws that hold the stepper motor together on a NEMA 23 square stepper. They are small (like 4-40 size) and NOT the mounting holes commonly provided. Any help would be appreciated.
    Necessity is the mother of all invention (unknown)
    My club home page www.lhmac.org
    Aug 2007
    422
    If you look at the link below, The screws I am referring to are the 4 phillips head screws not dimensioned (go figure)
    http://www.kelinginc.net/KL23H2100-30-4BM.pdf
    Dec 2006
    839
    Just taking a caliper and laying it across the tops of the screws (maybe not exact but very close) I get 1.200 between them going across the motor in one dirrect and then 1.930 between them the other way.
    This is a true nema 23 motor I am measuring which measure 2.25 each way across the outside of the motor. Some of those so called nema 23 steppers are really 60mm across motor diameter so they are sort of a hybrid in design. IDK if the assy screws are same place as real 23 steppers or not.
    The specs I gave you should be close enough for mounting purposes if using these for such. IDK if its close enough for a threaded application to match up or nut ( could be, maybe not).
    If your needs are for exact specs then PM me and I will take some drill rod and remove screws to get exact possision. I did raise the screws and measure there diameter and then across them to end up with the same specs I gave already so it should be dead on.
    Jess
    GOD Bless, and prayers for all.
    Aug 2007
    422
    Thanks Jess. That will work. I had scaled up some PDFs and that helped also.
  1. Eccentric bolts
    By JerryFlyGuy in forum Mechanical Calculations/Engineering Design
    Last Post: 07-27-2014, 02:18 AM
  2. Question about using nuts and bolts.
    By Broken Balsa in forum Commercial CNC Wood Routers
    Last Post: 03-03-2011, 04:25 PM
  3. Nuts and Bolts - THREAD
    By High Seas in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 04-17-2008, 05:46 AM
  4. u-bolts that don't require bending!
    By Rooney in forum Joes CNC Model 2006
    Last Post: 12-07-2007, 04:16 PM
  5. HSR rail bolts?
    By Gnu in forum Linear and Rotary Motion
    Last Post: 01-10-2007, 11:24 PM
