585,605 active members*
3,338 visitors online*
IndustryArena Forum > CAM Software > EdgeCam > EDGECAM LATHE THREADING OPERATION
    Sep 2010
    86
    Angry EDGECAM LATHE THREADING OPERATION
    Hello!
    Im operating Edgecam 2010R1, and im having problem with the THREADING OPERATION (CYCLE) for turning. I go to the the OPERATIONS menu, select THREADING and the prompt bar requires me to DIGITISE THE LINE TO THREAD(NEAR START POINT).
    This is where my problem starts. I dont know which line to digitise. I take a chance and enlight or enlight the surface where the thread should take place, and im presented a thread operation dialog. I fill the dialog box and when i press Ok at the end, i got an error message saying; DIGITISED SEGMENT IS NOT A VALID DRIVE LINE, and the prompt bar asks me to DIGITISE DRIVE LINE.
    So, i would like to be helped to understand, WHAT IS THE DRIVE LINE, and how to digitise it.
    Thanks in advance.
    May 2004
    4519
    Not having done any work in EdgeCAM for lathework, the following is just a guess based off other software I have used. I am assuming you are working with a solid model. EdgeCAM wants a line and not a surface. You will have to extract/create a line where you want the thread to go and then select that line.
    Sep 2008
    24
    1 Create a new turn feature
    2 Select face you wanna thread
    This creates a turn feature
    In manufacture mode digitise the line or select it in your
    feature browser
    First half of line gives you RH
    Last half of line gives you LH
    Sep 2010
    86
    Smile
    Thank you very much to Txcncman and Mimer. Your comments have been really helpful. You guys are great.
  1. Anyone ever put an X/Y table on a Hardinge 2nd Operation Lathe?
    By bogiestl in forum Vertical Mill, Lathe Project Log
    Last Post: 10-08-2011, 02:21 AM
  2. Lathe type operation on a cnc mill
    By MikeA in forum Mastercam
    Last Post: 04-15-2011, 10:56 AM
  3. NX Lathe Threading Operation Help Need Pls!
    By Paragon36 in forum UG NX
    Last Post: 03-25-2011, 09:59 AM
  4. programming Lathe operation to run on my Mill
    By rms2k in forum G-Code Programing
    Last Post: 11-11-2010, 01:49 PM
  5. What book to buy for explaining lathe operation
    By sunnyday in forum Mini Lathe
    Last Post: 08-20-2009, 04:58 PM
