585,763 active members*
4,408 visitors online*
IndustryArena Forum > MetalWorking Machines > Dyna Mechtronics > 1997 DYNA MYTE DM4800 VMC to Mach3 Conversion
Results 1 to 7 of 7
    May 2007
    100
    We are retrofitting our new DM4800 to Mach3. The details are located on the Mach3 Site:
    JH
    May 2007
    100
    This is the DM4800 Start Picture
    JH
    Nov 2013
    23
    I have a dyna myte DM 2800 and would like to convert over to Mach3 as well. Would you recommend the Gecko G540 with smooth stepper for this conversion? Any advice would be much appreciated.
    May 2007
    100
    There are some many things to consider when doing a conversion, my advice is to read up on all the "successful" builds you can and see what will work for your project and skill level before deciding on the architecture.
    JH
    Nov 2009
    4415
    Though this combo would work well. You will find the gearing is the biggest hindrance. It really just depends on the speeds you desire. If you like fast rapids a solution to the gearing will be required. Is your 2800 complete? If so you might want to interface with it.
    Quote Originally Posted by Robonut View Post
    Nov 2013
    23
    Not complete yet. The G540 & smoothstepper are on the way. I would really like speed and performance. Will the G540 do this wired in series (60IPM with 100IPM rapids with original gear reduction/power supply/motors) or should I upgrade to the G203 wired in parallel? Maybe I'm overdoing it and/or wishful thinking. Basically would like to at least match the Dyna original speeds.
    Power supply 48V DC 300 Watts 7Amps
    Stepper motors (P852-508-B)
    Belt reduction 2:5:1
    Ball crew 2.5mm pitch
    I also own a Taig cnc mill for over 12 years now and the speed and performance is poor. It's like watching paint dry
    Nov 2009
    4415
    Sorry for the hijack.
    You will get the rapids of the Dyna as it was intended with the G540. The smoothstepper didn't give me much of an increase in speeds, smoother to some degree. The problem is the gearing, ditch it and the machine will fly. My 2400 was running 101,000 steps per inch at 10x microstepping. My G0704 runs only 2000.
    A lazy man does it twice.
  1. Replies: 195
    Last Post: 03-02-2014, 02:17 AM
  2. Dyna DM4800 pre purchase questions
    By kentster in forum Dyna Mechtronics
    Last Post: 02-15-2012, 08:45 AM
  3. Did my Dyna Myte explode?
    By mfgbydesign in forum Dyna Mechtronics
    Last Post: 08-06-2011, 08:30 PM
  4. DYNA MECHTRONICS DYNA MYTE 3000 AND 2800 WANTED!!!
    By britcollector in forum Want To Buy...Need help!
    Last Post: 02-23-2010, 04:20 AM
  5. Help with Dyna Myte 2800 Conversion
    By UWP_Wes in forum Uncategorised MetalWorking Machines
    Last Post: 08-24-2009, 05:02 AM
