585,581 active members*
4,012 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Adjust Reference Position Return - 10M
Results 1 to 12 of 12
    Mar 2008
    150
    Wich parameter do i adjust the reference position return point with?
    Or how do i do this? My machine sometimes goes into soft overtravel alarm when i do reference return...
    Thanks!
    Kitamura Mycenter 1 -83 with Fanuc 3M-C and Mycenter 1B -85 with 10M control.
    Yes, they are old..... but i still like them!
    Aug 2011
    2517
    check this thread for a possible solution....
    http://www.cnczone.com/forums/fanuc/...ankenmill.html
    Jun 2008
    1511
    You can do a gridshift or you can adjust your softlimit settings as long as they are not too close to the end of the stroke.
    These should be 5220 for positive and 5221 for negative in your control but double check as I am going from memory. I usually adjust my softlimits 3mm past the reference position.
    Stevo
    Mar 2008
    150
    Ok, thanks for your info!
    Jun 2008
    1511
    Your welcome. Let us know how it comes out.
    Stevo
    Sep 2011
    Page 43 & 44 of the 10M - 12M Fanuc Operator's Manual says that parameter #1240 will change your machine's Z0 (for the machine coordinate system).
    Jun 2008
    1511
    Quote Originally Posted by Joe.B View Post
    1240 is just the 1st reference point that you set from your origin position. This is a different function that does not pertain to the manual reference of the machine at powerup. If he had no problems referencing the machine and then programmed a Z0 and it overtravled then this would be where you want to make the adjustment but that is not the case here.
    Sometimes your 1240 will be set to the position of the machine origin. It can get a bit confusing to some because it all depends on the terminology that you use. Some say home, others say reference, or you can say origin but they really all mean different things.
    To simplify it parameters 1240-1243 act more like G54-G59 workcoordinates.
    Stevo
    Sep 2011
    Stevo:
    Yes, all these Fanuc terms/definitions do tend to get silly. I had assumed that he had basically pressed ZRN, then Z+ and when the spindle made it "home," it over-traveled on him.
    Anyhow, if you would... I'm wondering what your take is on this other thread over here:
    http://www.cnczone.com/forums/fanuc/...correctly.html
    It deals with Z on a 10M Fanuc controller as well.
    Jun 2008
    1511
    I am making the same assumption that it is alarming out when he is trying to zero return the axis. I was just pointing out that he needs to either gridshift, change softlimit parameters, or physically move the switch. 1240 parameters won’t help in this case.
    I started to read your thread the other day. I will try to read in more detail and chime in today.
    Stevo
    Dec 2008
    239
    Overtravel
    See the machine is in Metric or Inches , also see the Mirror image , If both are ok , Make the Soft OT param maximum , and see the alarm of OT in Screen. Is it recognising the SOFT OT ALARM or Not?
    Mar 2008
    150
    Thanks all for your help, info and suggestions!
    Unfortunately it doesn't seem to be an overtravel...
    This is not happening when i start the machine and first do a reference "zero" return (after moving from the limit switch's).
    It happens suddenly - and not often, when i'm going to change tools / or just go to "zero" in program with G91 G28 Z0 Y0.
    Suddenly the machine stops and it sounds like someone pressed and directly pulled the emergency stop! The machine stops and just "stands" like it has read M30 before it reaches zero. No alarm or anything... Just to start program over again from beginning.
    I havent done much testing around this and doesn't remember if it was Z or Y that didnt reach it's zero point but i will check this as soon as it happens again. I was assuming that it did alarm soft overtravel, but the last time it didn't so noe i'm not so sure about that...
    Dec 2008
    239
    Ot during ref
    When it over travel it is soft or hard ??? what is the alarm Number?
  1. Fanuc Zero Reference Return Problems?
    By grege101 in forum Fanuc
    Last Post: 09-19-2023, 12:52 PM
  2. Reference return incomplete
    By Leha_Blin in forum Fanuc
    Last Post: 08-17-2011, 04:22 AM
  3. G30(reference point return)
    By Reg wharton in forum Daewoo/Doosan
    Last Post: 06-13-2008, 11:32 AM
  4. Spindle Orientation Position Adjust
    By pinguS in forum Fanuc
    Last Post: 11-16-2006, 05:02 PM
  5. Return through reference point?
    By RBrandes in forum Haas Mills
    Last Post: 12-02-2005, 04:49 PM
