585,575 active members*
3,594 visitors online*
    Sep 2011
    cutting aluminum
    how deep of passes would you take with contouring with a .062 end mill?
    May 2004
    4519
    On NFL logos, probably 0.031 max DOC should work just fine on aluminum.
    Aug 2008
    292
    DOC for end mill
    depth of cut for an end mill is based on many factors like
    1) length of end mill sticking out of collet
    2) what material you are cutting (aluminum or stainless steel)
    3) SFPM and thus rpm you are running at
    4) chip thickness or Feed rate
    using a 50% DOC depth of cut on a long end mill on stainless is a sure way to break end mills
  1. Cutting Aluminum On X1 CNC
    By DFason in forum Benchtop Machines
    Last Post: 08-16-2010, 09:43 PM
  2. I need help with cutting aluminum bar
    By mikey74063 in forum MetalWork Discussion
    Last Post: 04-05-2010, 07:50 PM
  3. Cutting Aluminum
    By darylprice in forum DIY CNC Router Table Machines
    Last Post: 07-03-2006, 04:51 PM
  4. K2 cnc Aluminum Cutting
    By Ed Williams in forum MetalWork Discussion
    Last Post: 03-16-2006, 07:38 AM
  5. Aluminum Cutting
    By Tazzer in forum DIY CNC Router Table Machines
    Last Post: 07-29-2003, 06:09 AM
