585,685 active members*
4,893 visitors online*
IndustryArena Forum > CAM Software > CamBam > Square corners
Results 1 to 7 of 7
    Sep 2011
    Square corners
    I have just started using camBam with mach 3 and have cut a few inside pockets nicely, However when i come to machine the outside of a simple square it runs the cutter around on a radius using G3 and I,J codes ,, How can i stop this from happening as i need a square corner,, Must be a setting in there someplace its drivin me mad
    Regards
    Bernie
    Sep 2009
    22
    assuming this is a 2d part and you did not import a drawing, instead of drawing a square box and having your endmill go around the profile draw 4 lines extending them past the profile of the square or rectangle then pick one line at a time forcing your program to cut 4 straight lines one on each side of the profile. my software gives me the option of square or round corners, I have to put in a radius if I want one.
    If the radius is the same as the tool's radius, the corners will still be square. Cutting a square this way is preferable, as the tool doesn't have to stop at each corner, which can cause machining marks. Some CAM programs call this "rolling around" corners
    In the attached image, the red lines are the toolpaths. Both parts (black lines) will be exactly the same.
    Mar 2011
    525
    Have you done the actual cut and the part came out with rounded outside corners? I have never seen that happen. The tool path is a radius like the picture posted above but the part comes out square.
    Quote Originally Posted by bjay View Post
    Regards
    Bernie
    Sep 2011
    Thanks for the advice , I will machine a part today you could be on the money with the roll around corner , Will report back
    regards
    Bernie
    Feb 2005
    521
    One feature that may help:
    In CamBam, from the View menu 'Show cut widths'.
    This will show the width of the cutter as a shaded area as it moves along the toolpath. The shaded area shows the stock that will be removed.
    The image shows 'Show cut widths' turned on for cutting around a rectangle.
    www.cambam.co.uk
    Sep 2011
    I have just machined a cut in a piece of wood and yes it has square corners, My mistake
    And i had the view cut width turned off it does make it easier 10bulls ,, I am using this machine for electrodes for the edm , and it makes it easy for machining rough and finish electrodes around .5 smaller for the rougher,, These are machined in graphite and that is nice to cut only very dirty and dusty,And will break if to much pressure ,, These are then used for making injection moulding tools
    Thanks heaps for your help ,, Top forum
    Bernie
  1. Milling Square Corners
    By cnckid in forum MetalWork Discussion
    Last Post: 03-30-2011, 12:06 AM
  2. Inside Square Corners
    By Magnum164 in forum Tormach Personal CNC Mill
    Last Post: 08-29-2010, 04:07 PM
  3. square corners getting rounded off
    By SatanKlawz in forum Uncategorised CAM Discussion
    Last Post: 06-30-2010, 02:33 AM
  4. Square hole in square tube
    By bubblybill in forum MetalWork Discussion
    Last Post: 09-21-2009, 04:18 AM
  5. Radius's appearing in square corners
    By simso in forum Mastercam
    Last Post: 01-03-2009, 05:10 AM
