585,575 active members*
3,852 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Reverse Direction
Results 1 to 9 of 9
    Sep 2011
    Reverse Direction
    Hi, just getting started in Bobcad and need help. I created a gear with 60 teeth and about 8" in diameter. I can establish the tool path but it's cutting inside the gear instead of outside. So I click on reverse direction which should change to the outside. But it does not. I tried on a simple gear and it works okay. Any ideas?
    May 2008
    244
    if v24 tool path on inside
    click start point
    click reverse direction should get arrow
    click arrow on geometry to swap
    then recompute tool path
    edit
    sorry you do not have to click the arrow
    just click direction and recompute on new build
    Sep 2011
    thanks, I did that but once recomputing the tool path it stayed inside. Your suggestion works on a small gear but not this one
    May 2008
    244
    i can not reproduce here
    what ever i try it swaps sides
    you might upload your file so someone can look at it
    its something simple
    file must be zipped to upload
    Sep 2011
    Here is the file. Perhaps there's something wrong with my system.
    Attached Files Attached Files
    Dec 2008
    4548
    Need the feature and geometry selection for the file....
    Feb 2010
    71
    Take a close look at your drawing, pay attention to the fillet at the bottom of the teeth.
    Doug
    Dec 2008
    4548
    Also a note about your geometry..
    More of a stickler, there is a double line here:
    More of the underlying cause of issues you may be having could be the root of the gear is malformed.. Perhaps look at the numbers used and recrunch.
    If you zoom in to a single tooth and view these areas here:
    Then window zoom all the way to one of those single points to see whats going on...
    Perhaps the root radius was set too large for the other specs and you are getting a foldover there.
    [EDIT] Dougl beat me to it!!! [EDIT]
    Sep 2011
    Perfect!, I did not think about looking closely at the drawing.
    Thanks.
  1. DC motor reverse direction
    By bigalow in forum CNC Machine Related Electronics
    Last Post: 04-16-2010, 08:42 PM
  2. Reverse Motor Direction
    By electric2u in forum Mach Software (ArtSoft software)
    Last Post: 02-19-2010, 06:46 AM
  3. How can I reverse the direction of one motor using turbocnc?
    By jetijs in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-29-2008, 01:23 AM
  4. Reverse direction?
    By HakBot in forum G-Code Programing
    Last Post: 11-19-2007, 11:30 PM
  5. Reverse axis direction?
    By saturnnights in forum Machines running Mach Software
    Last Post: 03-29-2006, 03:40 AM
