585,951 active members*
3,843 visitors online*
Results 1 to 8 of 8
    Mar 2008
    40
    Spindle speed slows down
    Hi
    I have Tormach 1100 and it looses spindle speed. Here is the problem I have been running for about a hour and it will drop the spindle speed 200 rpm. the feed rate is 30 and the depth of cut .020 3/8 end mill spindle speed is 1200. I have not been running a hour strait 3or4 minutes between parts.
    Thanks for the help
    carlboe
    Sep 2008
    325
    Is the spindle drive belt tight?
    How do you know how many RPMs it is dropping? Have you put a tachometer on it?
    Mar 2008
    40
    Yes I put a tachometer on it and belt is not that tight.
    Carlboe
    Jun 2006
    2512
    Do you have the latest frequency converter (with LCD panel), if so have you looked to see if there is any corresponding change in frequency output. Apart for motor slippage due to load I thought that the motor speed should follow the frequency.
    But what do I know.
    Phil
    Quote Originally Posted by carlboe View Post
    Hi
    Thanks for the help
    carlboe
    Aug 2009
    986
    I wonder if it's related to motor temperature.
    Frederic
    Nov 2006
    134
    I have also experienced a similar spindle speed problem, and in fact still do now and then. Tormach suggested that I wiggle all portions of the parallel port cable path going from the control computer all the way up to the machine control pcb. I found that wiggling just the parallel port ribbon cable connector at the machine control board seems to fix my issues, until they crop up again, days, weeks or months later. I need to get a replacement ribbon cable, as I'm fairly confident that is in fact the cause of my spindle-speed errors, which sound much like what you are experiencing.
    Oct 2008
    103
    +1
    I had moved my Tormach about 1600 miles via the back of a Penske truck a couple of years ago. Ended up with several problems/glitches including speed control. Greg at Tormach suggested the same as Bobeson. I pulled and re-installed all the ribbon cables and haven't had a problem since. Hopefully, Carlboe, it's "just a loose wire".
    Nov 2012
    104
    Re: Spindle speed slows down
    I just had mine do this, definitely something lose or just a bad contact because you can tap the cabinet and the rpm will pick back up even though the monitor still shows the correct rpm.
    How do I know the RPM slowed down? U can hear the spindle rpm drop, u can hear the one of the cut completely change, tap the cabinet and the rpm comes back up to normal.
    Add this to the long list of BS to be expect from Tormach
  1. SL-20 Spindle slows down and stops with 200% load?
    By colton_m in forum Haas Lathes
    Last Post: 08-21-2013, 06:55 PM
  2. Replies: 1
    Last Post: 08-02-2013, 10:07 PM
  3. Does feed slow if spindle slows?
    By Spinnetti in forum Tormach Personal CNC Mill
    Last Post: 07-01-2013, 01:03 AM
  4. Spindle speed slows down
    By carlboe in forum Tormach Personal CNC Mill
    Last Post: 02-11-2012, 06:55 AM
  5. BPSeriesI / Centroid control- Spindle speed all out of whack with speed dial?
    By peter.blais in forum Bridgeport / Hardinge Mills
    Last Post: 08-08-2006, 09:29 AM
