585,970 active members*
4,369 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > How can I open Chuck 1 and pull back Chuck 2 at the same time?
    Jun 2006
    59
    My wonderful boss bought me a Multus. I'm trying to transfer from Chuck 1 to Chuck 2. Chuck 1 is a collet chuck(not dead length or true length). Chuck 2 is a 3 jaw. I have a casting that is 2.1in diameter with a 5/8 boss on the top. I'm chucking on the 5/8in boss in the collet chuck and turning the OD and facing one side. When I bring chuck 2 up to transfer and command chuck 1 to open it alarms out on me because chuck 1 opens and pushes out against chuck 2. My first thought was i'll just move the W back as the chuck opens but it doesn't work.
    G84 G1 W50. F.1.
    Anyone have any ideas? Maybe an interlock I don't know about? I don't want to remove the collet chuck because I only have 30 parts and the next job is a barfeeder run where I'll want it back on.
    Jun 2006
    59
    I've basically come down to closing the two chucks. Having an M00 and then manually opening the chuck and moving W back at the same time. If I program it to move back and open at the same time (M84 G0 W50.) It's completes the M84 before it moves causing it to alarm out again. I need someway of forcing it to move W at the same time as the M84 command is being initiated.
    Apr 2009
    1262
    Try your M84 with a M64 (Ignore general M-code answer (if you have the cycle time reduction function)). Use M62 to confirm ignored M-code.
    The M-code is optional on most machines except sub-spindle machines, so it will most likely work on your machine.
    Best regards,
    PS> now you know why dead length chucks are recommended... ;-)
    Jun 2006
    59
    IT WORKS!!! Thanks a lot!!!! M84 M64 G0 W50. Did it.
  1. Chuck will not open
    By bruiserba in forum Okuma
    Last Post: 08-30-2019, 07:32 PM
  2. lathe chuck open/closed parameters
    By PinnacleMachine in forum Fanuc
    Last Post: 12-03-2009, 03:35 AM
  3. Open and close while running HL-2 chuck??
    By acrodave in forum Haas Lathes
    Last Post: 08-14-2009, 05:29 AM
