585,996 active members*
4,803 visitors online*
    Sep 2011
    ST20 drills off offcenter
    I am having a problem drilling on center. Could someone explain either how to correctly set up a drill or enter an x offset so that the machine will drill on center? Thank you
    May 2004
    4519
    You did not say what type of tool holder you are using. You can put a piece of drill rod in place of your drill and use an indicator attached to the chuck to sweep in the drill rod and see which direction it is off.
    As a work around, make your own drill holder bushing. Mount some round bar stock in your drill holder and put your drill in the chuck and drill out the bar stock. Be sure to mark the stock for alignment to the holder. Then take the bar stock out and drill and tap some set screw holes or split it on a band saw to make your own collet. Will only work for that size drill, in that holder, and probably only at that tool station.
    Jul 2005
    12177
    If my memory serves me correctly when you are in Handle Jog with the Offsets page on screen you can push F2 and that will enter the X offset to put the centerline of the drill holder on the spindle centerline.
    May 2004
    4519
    @Geof - I should have mentioned that first. Guess I assumed he would know how to set X offsets (even though he did mention it in the OP).
    Yes, you can change your X offset to adjust for some misalignment on the X center line. Does nothing for the Y axis. Still a good idea to indicate things to see where you are at.
    Sep 2011
    Thank you all so much......I am new to CNC and doing this alone and with out much training....
  1. Mazak ST20 ATC M/C Drilling Operations
    By diesel_dan in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-06-2011, 02:33 PM
  2. new ST20 any opinions??
    By gixxergary in forum Haas Lathes
    Last Post: 05-11-2011, 09:10 PM
  3. Carbide Drills 3x 5x 8x Diameter Drills
    By CDTooling in forum News Announcements
    Last Post: 09-10-2010, 02:37 PM
  4. There's Drills, Mills and Mill/Drills so what's the....
    By JWB_Machining in forum Uncategorised MetalWorking Machines
    Last Post: 05-20-2009, 03:04 PM
  5. PCB Drills
    By aggie_67 in forum CNC Machine Related Electronics
    Last Post: 03-07-2007, 04:47 PM
