Im running behind on this job. Would like to see if you guys could speed up my learning curve. I attached some pics of my set up and part. I can also e-mail the MC filr to you if you think you need it. The part one the side with no holes, is the blank stock.I need to spot face and drill. Then on the other side, I will be doing the od and chamf. I believe I need to use 5th axis curve, with a 4th axis output, but I cant seem to get it. hopefully guys can help. Thanks
