Features
Metal Laser Cutting machine RL1530-YAG-500
1, High precision: applicable for cutting precision parts, calligraphy and painting.
2, Fast speed: its speed is 100 times more than line cutting.
3, Small heat-affected zone, not easy to metamorphose, cutting edge is smooth and beautiful, no need to do after-process.
4, High performance: Its price is only 1/3 of similar performance CO2 laser cutting machines and 2/5 of CNC punch machines.
5, Low operation cost: its operation cost is only 1/8 to 1/10 of similar performance CO2 laser cutting machines.
6, Low maintenance cost: only 1/10 to 1/15 of similar CO2 laser cutting machines and 1/3 to 1/4 of similar performance cnc punch machines.
7, Steady performance can ensure the continual production. Solid YAG laser equipment is one of the steadiest in the laser field.
8, Compare to CNC router, YAG laser cutting machine have following advantage.
(1) Can process various complex structures, any image drawing by computer.
(2) No need to open mode. Only need design the file from computer, then the product can come out immediately.
(3)YAG cutting machine with automatic tracking system, is able to complete the flat cut and a variety of uneven surfaces cut.
(4) YAG laser cutting machine can cut complex technical requirements that can not be done with CNC Router.
(5) Can produce the products with smooth surface, which CNC router is hard to achieve.
(6) Molding body (less than 0.5 m thick) need the whole trench processing. CNC router can not handle it, but YAG laser cutting machine is workable.
