585,992 active members*
5,946 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Haas Mill VF-2 C-axis motor overheat
Results 1 to 9 of 9
    Mar 2011
    Haas VF-2 Alarm 272 c-axis motor overheat.
    Please let us know how to solve this problem. Thanks.
    Feb 2010
    1184
    A little more information would be helpful here.
    When does it alarm?
    What is the machine doing when it alarms?
    Is it really overheating?
    Is the fan running?
    What have YOU done so far to help fix your problem?
    1880
    bet its an amp... a pure guess but that's what its been on me every time i get a overheat.
    thanks
    Michael T.
    "If you don't stand for something, chances are, you'll fall for anything!"
    Aug 2010
    579
    +1 "Need More Information"
    What is the machine's serial number?
    Is the alarm resettable immediately?
    Once reset, how long until the machine alarms out?
    Ken Foulks
    Mar 2011
    Is the alarm resettable immediately? NOP !!!
    Mar 2011
    When does it alarm? When set at c axis in program
    What is the machine doing when it alarms? Stop & couldn't reset.
    Is it really overheating? Nop !!!
    Is the fan running? Yes
    272 C-AXIS MOTOR OVERHEAT - Servo motor overheat. The temperature sensor in the motor indicates over 150° F. This can be caused by an extended overload of the motor such as leaving the slide at the stops for several minutes.
    Aug 2010
    579
    The thermal sensor in the motor is indicating that is open. Either the sensor is bad, parameter 176 bit 14 could be set to a 0, or maybe a cable is not sending to the mocon. In any case it is better to contact the local dealer for assistance in solving this issue.
    Ken Foulks
    Dec 2010
    154
    What is "C" axis on a VF2??? My machine uses "A" axis... I've even heard of "B" axis but what is "C" Axis on a vertical mill?
    1880
    I believe the C axis is the tool holder so probably the rotation motor but I've always had problems with the in and out motor.....or if its a sidemount disregard what i say.
    thanks
    Michael T.
  1. 2 month old Haas VF2D, Regen Overheat?
    By locash in forum Haas Mills
    Last Post: 06-04-2014, 01:55 AM
  2. Fadal 4020 Z axis motor overheat
    By dmac88 in forum Fadal
    Last Post: 09-28-2009, 02:51 PM
  3. Servo Motor OverHeat
    By Shvenk in forum Servo Motors / Drives
    Last Post: 07-03-2009, 07:25 PM
  4. X Axis Servo Motor Overheat
    By mtgpaul in forum Colchester Tornado lathes
    Last Post: 10-18-2008, 01:37 AM
  5. 702 DC motor overheat
    By Rocksalt in forum Fanuc
    Last Post: 09-29-2006, 11:13 AM
