Hello!
Today I tried, to machine 3D part using advanced rough strategy. My problem is that it dos not mill to the bottom of the part, so there stays some left material.
As you can see on the picture below (all other toolpaths except 8mm tool adv. rough are blank). The tool path does not go to the bottom. I tried to solve the problem with smaller depth of cut, and with adding intermediate steps. XYZ allowance is set to 0.
In help there is description of Advanced rough:
The Advanced Rough is a roughing toolpath strategy which machines the surfaces at one constant Z-depth after another. However, this process will recognize open areas of the model and also offers semi-finishing within the same toolpath result. This 3-axis toolpath is available in the BobCAD-CAM PRO upgrade.
So I believe there should be possible to mill to the bottom of the model.
I have attached my model. I am using BobCAD-CAM V24 Build 376.
Thanks for the help.
