The typical off the shelf door and interlock switches have an actuator (key) that when triggering the switch has a two stage operation, IOW the key strikes two operators in the switch for it to register, to avoid simple 'jimmying'.
I have made a striker or key for these before, but I am not sure if these are what are fitted to Haas unless there is a make/model on the switch.
Al.
Albert E.
