585,956 active members*
4,482 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Rotory tool path is posting out new cord with every path?
    Dec 2006
    116
    I'm trying to do a simple contour in a shaft to make splines, and when i use transform to rotate the path around the shaft, then post the code I get a new work cord for every position. What am I doing wrong? See attached files. On x5
    Attached Files Attached Files
    WANNA GO FASTER
    May 2004
    4519
    I can't open X5 file. But, I bet when you used transform, you checked the box that outputs a new coordinate for each transformation.
    Apr 2003
    3578
    Set it to Maintain Source operations under Work offset numbering,review picture
    Cadcam
    Dec 2006
    116
    Thank you cadcam. The one thing I didn't do was lock in the work offset to -1. I checked the box but left it at 0. Thanks again.
    WANNA GO FASTER
  1. No tool path?
    By spincaster in forum Rhinocam
    Last Post: 04-07-2010, 03:37 AM
  2. Which Tool Path ?
    By weirdharold in forum UG NX
    Last Post: 11-24-2009, 06:07 PM
  3. can't get the tool path right
    By msn_jrd in forum Mastercam
    Last Post: 07-21-2008, 04:43 PM
  4. need tool path
    By wcopley in forum BobCad-Cam
    Last Post: 06-19-2008, 11:13 PM
  5. 3-D TOOL PATH
    By reedmiles in forum BobCad-Cam
    Last Post: 02-03-2008, 02:08 AM
