I have end mill holders that have a set screw on the side to secure the tools by tightening on the weldon flat of the tools.
Unfortunately most of the tools I have dont have eldon flats on them naturally and are natively cylindrical on the shank.
What method can I use to fabricate the flat on the tools so I can use the end mill holders I have?
I dont have a grinder, otherwise I might do that. Will precision fly cutting work or maybe end milling it?
The difficulty is the tool shanks are as hard as the cutting edge so its probably not good for the tool trying to cut the flat onto the other tool.
What do you suggest? (I agree grinding is best but I dont have a grinder)
