Originally Posted by
MetalShavings
Before you create the "Planing" operation in SprutCAM and you add some stock to the Z-axis, (the top surface of your stock-block) Does SprutCAm automatically know that the same amount of stock that you just added to the Z-axis is the amount that SprutCAM is being asked to plane off in creating such an operation.
I'm not clear on this. If this is the case, and other than being able to decide how many passes your cutting tool makes to achieve the final depth of your cut, what's the real purpose of all those other input fields?
