585,754 active members*
3,679 visitors online*
    Feb 2009
    13
    HELP: mazak alarm
    having servo alarm on mazak milling center, alarm is 31 servo malfunction 1, followed by these numbers &00000032, &0002. alarm in electronic panel shows, (MAG) is AL-01-N1-01. (ATC) is AL-01-N1-01. alarm cannot be cleared, and machine will not move from current location. MAZAK IS A VTC-200B, FUSION CONTROLS. HELLLLLP!!!
    May 2004
    4519
    What does the Mazak manual say for this alarm? What happens when you power down and the restart the system? What happened just prior to the alarm?
    Feb 2009
    13
    mazak alarms
    nothing in manuals about this alarm. machine goes right back to the same alarm code, not able to clear alarm from panel, also not able to get any movement in X,Y OR Z. machine just finished machining a hole, came up to move to next hole location and 31 Servo malfuncton 1 alarm came up. here's some other info on this alarm.
    MAG (flashes) AL, 01,N1,01
    ATC (flashes) AL, 01,N1,01
    High gain servo amplifier (flashes) F3, E7, F2,32
    High gain servo amplifier (flashes) F1, E7,F1,E7
    Spindle amplifier (flashes) F4,E7, F4, E7
    Enhanced Converter (constant) 6
    these are in the main electrical panel
    Nov 2016
    Re: HELP: mazak alarm
    I see it is a while since there have been any replies to this. I had a problem similar to this on a Mazak Variaxis. To cure the problem I restarted the machine and held the contactor in for the hydraulic pump till the machine was up and running. It would seem that if the pressure sensor does not activate quick enough, it can cause this error.
  1. Mazak MYSTERY. HOW do you clear this ANNOYING Mazak alarm??!!! NOBODY KNOWS!!
    By Mill&Lathe in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-03-2022, 01:55 AM
  2. MAZAK ALARM 404
    By CHANDRU in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-18-2016, 07:44 AM
  3. Mazak alarm #260
    By ant771 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-30-2013, 02:43 PM
  4. Mazak QT 15 Alarm 14 Drive alarm z axis
    By Rodent73 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-12-2013, 01:21 PM
  5. Mazak SQT 18 205 alarm
    By twistedturner in forum Uncategorised MetalWorking Machines
    Last Post: 03-08-2009, 10:06 PM
