I have a 1989 Mori Seiki ZL-15 with a Fanuc 11TT Model A control. The belt on the lower X-axis broke while cutting which caused the turret to fall down to the bottom of its stroke limit. I replaced the belt, but now when the machine is powered up, I get an -X2 stroke limit alarm if I try to move it in the -X2 direction. This makes sense because of the turret falling and me hooking up the belt at that fallen position. So, I opened up the -X2 soft stroke limit and zero returned the machine. I put the stroke limit back to where it's supposed to be, and everything is fine. The problem is that when I restart the machine, I have to do the whole process over again. The machine at home position will give me a machine position of approximately X2 -7.5000 upon power up. As soon as I try to move in -X2 direction, I get the soft overtravel alarm again. I tried doing the P Cancel thing, but that does nothing. I want to know what I can do to get the machine to forget its old position. It's behaving like it has absolute pulse coders, but from what I understand, this machine is too old for that to be possible. So far, Fanuc has been unable to help me, so I'm hoping someone on here has an idea what might be going on. I know that I could just disconnect the belt and jog the motor to where it's supposed to be, but I'd like to know how to do this with the control. Plus, I'm quite perplexed and really curious what's going on here. Thanks.
